i have thirty models in one dgn.
most of the models are sheets.
the entity we are submitting to wants each sheet as its own dgn.
OTHER THAN: save as: filter one sheet model at a timeALSO OTHER THAN: copy the dgn 30 times, rename each dgn as its sheet, and manually open / delete the other models
does anyone know how to batch-save SEVERAL MODELS AT THE SAME TIME to their own individual dgns?
i have already read through 3 similar articles that do not quite explain if this is possible or how to do several at once.
no, i am NOT saving to .DWG i already know how to do that and it is not what i need.
please see and read screenshots
Jons solution maybe best. Another option maybe to save as DWG as there is an option to save as individual files and then run a batch process to save as DGNs
