A week ago, I created a custom ribbon in Connect that contains a new workflow, tab, panel and a series of buttons. Today, I wanted to update the icon on one if the custom buttons, but almost everything in the properties window for the button is greyed out. I can not update the Description, Key in or Icon Name because they are greyed out in the property window. How can I update the Icon file property for my custom button?
Note that some properties can be updated, such as size.
I figured it out: you need to load the dgn file in Microstations and then you can edit the custom menu items.
Answer Verified By: Brenden OReilly
Well, here we go again: Today, I need to update icons on my custom ribbon. I was able to do this on 1/3 and I wrote down the exact steps to be able to update my custom ribbon inside Microstation.
But when I open the dgnlib and follow the same steps today, most of the custom ffields, such as Icon Name, are greyed out again, in my custom ribbon.
Well, this is disappointing. I can't update any custom buttons, but I can update a custom tab. If I make any change such as updating the tab label or deleting a button and then click the apply button Connect Crashes with an error and then closes.
