I just started using MS Connect and the Background Map is a great feature, but unfortunately, after I installed NYSDOT Workspace and Settings, the view setup box for Background Map is not showing anymore, and I tried to right click to check presentation, it's checked already. What could be the problem?
does the design file have a coordinate system assigned ?
Timothy Hickman
Main: 877 627 3772|
Answer Verified By: Lucilia
It was not assigned a coordinate system. Now it works, thank you!
I'm having the same issue but my file does have a Coordinate System and when I set aerial it shows the Microsoft Bing logo in the bottom left but no aerial comes in
