Accudraw rotation
Hi
Does know why my accudraw rotation always goes back to Auxiliary when I turn it to View?...Even though I select Save settings it always goes back to Auxiliary....
Best regards Sigridur
  • The rotation setting in AccuDraw can be set to either "View" or "Auxiliary". The setting may be resetting to "Auxiliary" for several reasons, including:
    1. AccuDraw Settings Reset: AccuDraw settings can be reset when you close and reopen MicroStation or when you switch between design files. This can cause the rotation setting to reset to the default, which is "Auxiliary".
    2. Template Settings: If you are using a template file in MicroStation, the AccuDraw settings in the template may be set to "Auxiliary", causing the rotation setting to revert when you switch to that template.
    3. Key-in Shortcut: The AccuDraw rotation setting can be changed using the key-in "accudraw rotation [view|auxiliary]". If someone has used this key-in or if there is a macro that automatically changes the setting, this may cause the rotation setting to revert.
    To prevent the rotation setting from resetting to "Auxiliary", you can save your AccuDraw settings as a custom configuration file and load it every time you start MicroStation. You can also ensure that your template file has the correct AccuDraw settings and avoid using key-ins or macros that change the rotation setting.
    Andrew Bell
    Technical Support
    Bentley Systems
