How I should reverse broken text to normal text in microstation 2004 version by other than undo option?
Kindly provide me solution for the above question as soon as possible.
Except it is not available in CONNECT edition.
and DEFINTELY not in MicroStation 2004.
MaryB
Hi Sundaravadanam,
If not too much work has already been done, perhaps you could retrieve a backup copy of the file if it exists?Right click file in Windows File Explorer>Properties>Previous Versions tab
