What do you think to add key-in functionality to search bar in Connect ?
( with AI ;)
btw when you add voice commands directly in Microstation ?
MSVoiceCommands - A Voice Command Console for MicroStation and MicroStation based Design Applications - MicroStation Wiki - MicroStation - Bentley Communities
It's a little confusing what you're asking for in the first question as the Search section at the top right of the MicroStation application window is used to search the Ribbon for tools that are available. Yet, the Keyin dialog has always been a separate tool to insert any key-in that might be available for these tools. Are you wanting to integrate both of these together? How are you wanting AI in this? Maybe you could create a MicroStation Idea.
I'm not sure whether our developers have included voice operated command options, but I believe there are many add-on software available that have these sorts of capabilities. There are also the accessibility options that can be installed.
Control your PC with these 5 speech recognition programs | PCWorld
If anything, I would like an option to include key-ins in the search parameters, but NOT to execute any key-ins directly from the search parameters. Perhaps as search results it could have "Execute keying: xxx"...
--Robert
