I'm going to start remotely, but at pandemic I experienced some speed issues. I was using my home 100 Mbs FIOS. I read some of suggestions to improve the speed while using Micrstation, but I still don't know what internet speed is good, Should I get a better one? Thank you
Hi Lucilia,
In addition to what others have suggested, you might look into connecting your machine to your network router with an ethernet cable. No matter what your internet speeds are, having a hard-wired internet connection should be faster and more reliable than regular WiFi internet.
Also, some suggestions were made by another user in this forum thread. You might check this out.https://communities.bentley.com/products/microstation/f/microstation-forum/156166/microstation-connect---tips-to-speed-up-pefromanceHTH,Jayson
