When creating a multiline (for example a wall build up) - is there a way to create a multiline with a hatch already embedded into the multiline? i.e Brick hatch, Insulation Hatch, Blockwork Hatch).
Raster line styles are not a fill. They are raster tiles repeated along the line. There are some delivered with MicroStation CONNECT you can experiment with. If you can get them to work in your multilines there is information in the help about creating raster custom line styles.
Rod WingSenior Systems Analyst
