I have several dgn models and using Microstation Connect edition. I have been given the TFL_QAChecks.mvba file but no idea how to use it, or how to run the CAD QA process from within MIcrostation Connect, someone please help?
Would you be able to provide details for where this 'TFL_QAChecks.mvba' originated as it does not appear to be a tool provided by Bentley. It would also be helpful to provide details of the version of MicroStation CONNECT Edition that you need to use this in.
MicroStation Forum best practices
The following general Wiki helps to explain how to load and use any VBA macro that you may have been sent but it is always a good idea to go to the company or person where it may have originated.
Using a VBA Macro
Gurpal Kular said:I have been given the TFL_QAChecks.mvba file but no idea how to use it
TFL is presumably Transport for London? You work for one of the tube lines?
That VBA was developed by someone in TfL (or perhaps a contractor). Contact the person who gave you that VBA and ask for more detail.
StandardsCheckerController
Hi Andrew,
I'm using Microstation Connect Edition Update 17, Version 10.17.01.58.
The file originated from 'Transport for London/London Underground' and they have provided a PDF installation guide but it is quite complicated and what ever I try doesn't work.
Thank you for sharing the link, but when I try to open the Macro via Microstation nothing happens:
What can I do? I prefer not to ask LU as they would take a long time to reply, and I would have to go through our client.
