Hi All,
I am having one file where dimension style is defined. Based on the definition, if we preview it is showing the result as shown below.
For a new file, I have followed the same settings of Geometry, Units, Text, Symbology but for me the preview is showing as.
What could be wrong here?In the end, I tried importing the Dimensional Style from the reference file where it is showing correct result but surprisingly it is showing the different result in preview as well.I have checked the working unit settings for both the file and its same.Any suggestion/solution on it would be a great help
Which Version of MicroStation are you using?
It may be useful to provide the files in question if possible for other to comment.
Have you tried comparing the Imported Dimension Style with the existing one?
Just a guess- Preview of any kind will often display items using active parameters. So if your definition includes line weight, you'll see it, but if the line weight is not defined in the style, it will use whatever is active.
Connect r17 10.17.2.61 self-employed
Carl
I think it’s an issue of OpenRoads Designer program. I have reported SR for it.
Using the same dgnlib, if I create a new file *.Ddn then in preview of dimension style showing correct preview as expected.
Deepak
