Hi All, I have a conundrum I am hoping you can help with.
I have created a file from scratch as the error appeared on a separate file first.
When referencing in the units using Microstation all the units are all the wrong position. It appears that the X Y coordinates are correct but the Z coordinate seems to be giving me values centering around an AOD of Zero, whereas it should be ~+65.0.
The units do not 'select normally and i have to hover somewhere in the vicinity to try and select it as clicking straight onto the unit does not work.
I have opened the same file up in Bentley View Connect, Openroads and Openbuildings and the file opens normally. It is only when I open the file in Microstation does it produce this anomaly. Furthermore, it is only my Microstation that produces this, everyone else I ask to open it up gets the file looking how it should.
There are no drawn elements in the model and everything has been referenced, all the references are DWG files.
What is also strange is when I open those DWG files up within Microstation it is stuck on a Plan View only, I cannot rotate the model, it's like it is only 2D. Again, when anyone else opens that the file is 3D and then can rotate, the same happens when I open it with Autocad.
Below are my images of the various programs with the last one being Microstation.
Any help is greatly appreciated.
If your colleagues are able to open your file with no issue in MicroStation, then it certainly sounds like its specific to your install.
Are you using the same version of MicroStation as your colleagues and what is it?
Rather than opening the file where the DWg's are referenced what happens if you open the DWG file directly, do you see the same problem? If so check/compare your DWG Open options and associated Seed file are the same as your colleagues. (Possibly try Exporting the settings from a colleagues PC and import))
Have you tried resetting your MicroStation?
Carl Myhill
Technical Support Engineer
Bentley Systems
Answer Verified By: Leigh White
That's great, Resetting Microstation seemed to work. Thank you!
