I recently updated my Microstation from V8i to CONNECT but changed my preferences so I have the hotkeys and toolbar similar to the V8i format. I used the following links to do it:
How to display the V8i style Tasks dialog in MicroStation CONNECT Edition through Update 12
How to enable v8i keyboard shortcuts in CONNECT Edition
After updating, whenever I try to use the manipulate command (3), it gives me options to move, copy, etc but for rasters and not for lines and other objects.
Is there a way to fix this?
I've seen this mentioned here before. I forget it it was a version error or something to do with a custom workspace...
Try searching this board because this sounds very familiar. If I find it, I will link the discussion for you.
What version of CONNECT (10.xx.xx.xxx) are you using?
MaryB
This thread may have some useful information.
I believe this thread also may have a fix or workaround.
