I have a fairly busy 2d drawing. The previous user changed all the colors of the elements to a light gray . The levels still have the correct colors associated with them. Is there a quick way to change all the elements to color by level, or do I have to change each type of element Individually?
MIcrostation Connect Version 16
The following Wiki may help, You may also want to check View Attributes, and see if Level Overrides have been applied.
Yes, most easily done. Select All elements. Pick just the color, set it to ByLevel.
Answer Verified By: Anthony Hlad
