[CONNECT] Some Commands stop after one use.
Hello we changed from Powerdraft to Microstation Connect.
First thing i did was changing the Interface so that it looks the same like in powerdraft and also that i can use the same key shortcuts like before.
But now if i open a command via shortcuts everything is ok, but if i click on commands from the toolboxes that i pinned to the left side of the screen they stop after one use.
For example "move Parallel": i leftclick a line and its gets copied, but then the command exits and for the next "move parallel" command i have to click on the icon again.
Has anybody an idea how to change this?
thank you
