[CE] Associative Dimensions inside Cell break when stretched
Hello together,
I have a problem with associative dimension elements. When a associative dimension is inside a cell and dimensions are turned off via the view attribute, they don't update when they got stretched via fence and then get turned on again. Without a Cell around them, it works. I provide a gif and the DGN. The Top Element is the Cell. The dimension used on the bottom is the "Dimension Element" and the one on the left is "Dimension Linear".
One of our customers brought that issue to us. They used this exact workflow within V8i and there it worked without issues. Now with the Connect Edition, they continued using this workflow but broke multiple files.
Also the function "Dimension Audit" doesn't detect any issues. The associative
region doesn't work either but this also didn't work in the Microstation V8i.
I confirmed this issue using the Versions U15 to 17. In this clip I use 10.17.01.62.
dimension_issue.dgn
