Well, Bentley View Connect Edition does not open Rhino7 file.. very frequently.
It opens somethings but the others not, case by case. But i can't understand what it depends on.
And.. especially "cannot open" or "can open but very slowly" LARGE files as well.
Is it supposed to be like this when trying to open Rhino7 files? or are there PRO version of this viewer..?
Just this loading windows always...
Which version of Bentley View CONNECT Edition are you using? Maybe you need to ensure you have the latest installed.
MicroStation Forum best practices
There is a resolved issue listed for MicroStation CONNECT Edition (Bug 1092799) which may be related to the issue you've reported in Bentley View.
Resolved issues in MicroStation CONNECT Edition Update 15 (10.15.00.74)
Thanks for the reply.
But i installed this viewer some days ago,
and i'm using version 10.17.02.18 Update 17.
Can you share few Rhino 7 files which causing an issue to open at your end?
Regards,Pravin Sawant
