how do you save work set on MicroStation connect
What is the exact version no. (e.g. v10.x.y.z) of MicroStation that you are using? Use key-in VERSION to see the version no. in the MicroStation Message Center, or Help→About MicroStation in the backstage.
VERSION
See this blog that shows you how to obtain MicroStation's version number.
If you're using an additional product (e.g. ProjectWise, OpenXxx) let us know about that too!
Ramogale Selebogo said:How do you save work set on MicroStation CONNECT?
Do you mean a DGN Workset configuration file?
Hi Ramogale,
Once you create a WorkSet in the main MicroStation CONNECT Edition interface, then it should automatically be saved for future access.I would recommend checking out this video: https://www.youtube.com/watch?v=kpQzG5wCtc8&ab_channel=BentleyMicroStation
To create a WorkSet, you will need to create/activate a WorkSpace first.In the below screenshot, I have activated the "Example" WorkSpace and created the "test" WorkSet.To create additional WorkSets, click on the Create WorkSet option as shown.
Enter in the Name and Description.Leave everything else as the default values and click OK.
Now, the new "test2" WorkSet is available for selection:
