I recently had to update/reinstall Microstation CE and it no longer loads or recognizes my existing Workspaces or Worksets. I only see an option to migrate from v8i. The workspaces in question are located on a network drive.
Thank you.
I'm thinking the reinstall of MicroStation CONNECT Edition has reset your pointers to your networked workspaces. The following Wiki article should assist in getting these connected again with your current installation.
How to Network MicroStation CONNECT configuration after MSCE has already been installed
