My snap works on everything except multi-lines. On multi-lines it will only snap to endpoints or the line used to draw. This only seems to happen if the multi-line has been edited (ex. if construct corner has been used on it or it has an open multi-line cap).
Is this with 10.17.02.61? Unable to replicate.
Yes, on the newest update. After messing around with it more it seems to snap if I am zoomed out just not when I am zoomed in close.
Sounds like a typical Connect bug. They get rid of 3 and add 2. We are un-paid beta testers.
You can file a service ticket, my guess they'll be unable to replicate.
That is kind of what I was figuring too. This is also happening to other people in my office too. Just wanted to see if it was known.
Thank you though!
Hi Zach,Thanks for the post - sorry to hear that you are running into issues.Could you post a .dgn file with an example of this case so we can try to reproduce the problem? When you reply, you can just select Insert>Image/video/file.In the meantime, here are a couple of initial thoughts on this:- What is your snap mode set to? Try changing the Default Snap mode to something else. "Nearest" and "Multi-snap 1/2/3" are good for picking up many points on an element. (Drawing Aids Tab>Snaps Ribbon Group>Default Snaps- Check AccuSnap settings (small square with arrow in bottom right of above photo)- If you create a new file and create a multiline, can the issue be replicated?
-Jayson P.
