I am trying to add a row into an extg. table but can't get this to work as suggested in Help. I click the Table but don't see all the extra bits as shown below from Help. I also can't select cells.
If I click the table I do get the table tools in the ribbon but they don't do anything. I could have done this in excel which would have been easier but thought I would try tables!!
Apologies to all that replied. Just realised that I hadn't come back to you.
The solution, in the end, was an easy one!! I just had to change Element Selection to use handles and it then picked up the Table and all worked fine.
Answer Verified By: Jayson Perry
