I am chaining item setting key-ins with PLACE BLOCK ICON but I cannot seem to alter the Edge 1 checkbox and field.The available final commands in the key-in SET ITEM TOOLSETTINGS are- EDGETOGGLE
- ELEMENTAREA
- ELEMENTFILL
- ELEMENTFILLCOLOR
- LENGTH
- PLACEBLOCKTYPE
These are all self explanatory for which settings they can alter, but EDGETOGGLE [= number] and LENGTH [= number] only seem to affect 'Edge 2' and I cannot figure out how to affect 'Edge 1'Anyone able to enlighten me?
Doug Murray said:I am chaining item setting key-ins with PLACE BLOCK ICON but I cannot seem to alter the Edge 1 checkbox and field
One way to discover tool settings variable information is to record a VBA macro. Then examine the macro to see what application information it has captured.
Unfortunately I do not understand the syntax here.Are you able to extract the necessary key-ins from this?I try to avoid using macros at all costs and prefer to chain multiple key-ins together.
Doug Murray said:I try to avoid using macros
The sole reason for suggesting a macro recording is to reveal the inner workings of the MicroStation tool. There's no hidden agenda to persuade you to use macros in production.
Yongan.Fu said:The Edge1 and Edge2 are new options added in CE. The macro recorder can't record toggle Edge1
The recording has revealed that the required application variable is not published. Yongan.Fu will file a bug report in the hope of persuading the MicroStation developer to add support for that variable.
Jon Summers said:The sole reason for suggesting a macro recording is to reveal the inner workings of the MicroStation tool. There's no hidden agenda to persuade you to use macros in production.
Sorry for coming across as dismissive. My bad I absolutely do use macros for this purpose and is definitely the right path in trying to hunt down desired control.
I havent tested this but you could try stringing the three keyins from Yongan Fu with a ; between them and save as a custom F key combo that hasnt been used then you can launch the keyin at the press of an F key or modify to suit new values when needed .... personally I'd prefer to use a cell and scale , rotate as needed..
sorry no I longer have access to microstation as bentley dont let use use home licenses anymore even not for profit or helping forum...
Lorys
Chaining key-ins with ; is exactly what I'm doing. Usually to make sure tools always start in the configuration I want. Soooo annoying that you cannot switch off the settings being held over from previous uses. For example this is my key-in for composite curveplace composite;set item toolsettings arcangletogglelabeltoggle = 0;set item toolsettings arcradiustogglelabeltoggle = 0;set item toolsettings chngclosure = 1;set item toolsettings comparcangle = 0;set item toolsettings comparcradius = 0;set item toolsettings compcurvemodeoptionlabel = 3;set item toolsettings elementfill = 1;set item toolsettings elementfillcolor = 0;set item toolsettings planartogglelabeltoggle = 0;set item toolsettings smoothcornerstogglelabeltoggle = 0;choose element;place composite;lock templateassociation off;active priority = 0;active transparency = 40;active weight = 10;active style bylevel;active color bylevel;active level = "Default"
Starts the tool with my preferred settings and on my construction layer.
Below bug filed:BUG 1099506: Place Block Icon command doesn't support SET ITEM TOOLSETTINGS very well.
