When placing labels with leader, the in-line leader doesn't seem to have a level.
I wonder if it can take the properties of the text or the leader?
Can somebody help me with this problem?
Thanks in advance.
It would be helpful if you could provide details of the software and version you're using.
MicroStation Forum best practice
Generally, when you're using the Place Label or Place Note tool the in-line leader should be placed on the active level but may also depend on any settings you have defined in the tools or possibly in the Dimension Style you're using.
I have been able to replicate the issues with the In-Line Leader with the Place Label tool. It appears to work differently than with the Place Note tool. That is, the attributes and operation of the in-line leader in the Place Note tool does not appear to use any of the settings defined in the Dimension Style. The level, colour, line style, weight etc. are not defined on this section and the element is not selectable.
I have located the following Bug 653556: Place Label in-line leader cannot be selected and its attributes cannot be edited which I believe covers the description of your particular problem. You might think about raising a new Service Request and we can link this Bug for updates.
Use the old Analyze Element tool (key-in Analyze Element). This will allow you to select and change the attributes of the in-line leader. The new Element Properties dialog does not allow you to access and change the in-line leader.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
I made the Service Request.
Thanks, Andrew
Hi mwlong,
First time using the tool, but as Andrew said, the in-line leader cannot be selected.
Still, it's always nice to learn something new.
The in-line leader does have a level. You can see that by selecting the Line element in the Analyze Element dialog. The in-line leader will reside on the same level as the rest of the Note elements.
