I get the following error when opening a file:
I am pretty sure it is related to the manipulate toolbar because a couple of those tools no longer appear when I hit the shortcut key for those tools (9 and 0 below)
I am pretty sure this is related to a library file customization, but I don't know how to fix it.
Any help is appreciated.
Good chance it's just the path for the customized library file in Configuration Variables. IDK which one.
The following Wiki may be of help
(+) Error - Unable to load/create dialog item of type 'IconCmd', id - MicroStation Wiki - MicroStation - Bentley Communities
Answer Verified By: Brian Gacke
That link was helpful. Problem solved. Thanks!
