I have searched and cannot find an answer on this.
I recently updated to Version 10.17.02.61 and now having issues while copying/pasting dimensions.
I want to copy/paste from file to file to have the same orientation of dimensions. However, when I do this, the text changes to the color white each time.
I have tested this in a new file and checked my dimension styles to make sure they're matching the dgnlib settings. Copy/paste directly into that file and end up with the same results. (see attached).
Any ideas?
I get changing colors mostly with cut-and-paste in DWGs. If I remember correctly there might be a kind of seed-file involved with the clipboard. That file has a different colortable (?) Maybe sb can shine a light on this.
I remember having filed a service ticket but never got a real solution.
double check and turn off overrides in view attributes , now any differences?
instead of copy paste try xref the source file then use then copy paste, I also use the match/ change attributes Alt LMB,
Lorys
thats not a possible cause when you are in dwgs. Because they dont have level overrides.
