Suddenly i can no longer reference in "r13" dwg's or even saveas to a dwg , it appears to have only affect me,
we are running v8i, 08.11.09.919 as well as Connect and ORD, i assume some dwgviewer has been corrupted
Hi Karl,
Do you know if you have defined configuration variable MS_REALDWG_VERSION in V8i?
For V8i, which Autodesk RealDWG do you have installed? Did you try to repair it?
see communities.bentley.com/.../bentley-v8i---autodesk-realdwg-tm-faq
which version of MicroStation Connect are you using? The latest support RealDWG 2023. is Connect edition also giving you issues?
just did the repair in control panel , that didnt work
i dont see the Ms_..
it seems like you are using NYSDOT workspaces.
yes that correct, Custom version of it
