Export to DWG - Incompatible AEC Object Alert
When I export a DGN file with attached DWG references I get the "Incompatible AEC Object" alert.
This happens even though I have the following config variable defined:
MS_OPENDWGAEC = 1
This makes it impossible to run a batch convert job.
Is there something I'm missing? Is there another variable that needs to be set?
I'm using Microstation CONNECT Update 17 version 10.17.02.61
