Export Item Types to Excell from All Models
Hi
I am struggling with exporting Item Types instances from ALL MODELS to the excell sheet.
Actually, only the item type from the active model is exported.
I have a number of sheets in my dgn file, title blocks are populated with item types that come form the title block cell. I want to export Item Types from all sheets to update title blocks in a bulk process in Excell and then import back to dgn.
do I miss sth or exporting from All Models is broken?
I am using OpenRoads Designer based on Microstation platform: (10.17.2.454)
