The text from autocad dgn file is showing only borders in microstation.This is not happening all text on same layer inspite of having same attributes etc.
I am using the connect edition.
Is Fill turned on in your view attributes? Is there a display style set for your view?
Are you certain that piece of text has the same font as the rest? Is the font a TrueType font or an AutoCAD SHX font?
What version of CONNECT are you using? What version DWG file is this?
MaryB
Some of the ACAD fonts just look like that. Fill makes no difference.
Isolate what that font is, find one that looks better (true type maybe), and change them all or just modify the text style.
(timesout)
some of the apparently filled ACAD fonts are actually hatched.
Nature of the beast
Thanks for responding.
Fill is turned on in attributes.
Is there a display style set for your view-will see how that is done.I don't know this.
Yes its is actually same as rest.
it is a true type font
2019 is the autocad version and Microstation connect V8
Sanyukta Joshi said:Microstation connect V8
No such product!
What is the exact version no. (e.g. v10.x.y.z) of MicroStation that you are using? Use key-in VERSION to see the version no. in the MicroStation Message Center, or Help→About MicroStation in the backstage.
VERSION
See this blog that shows you how to obtain MicroStation's version number.
If you're using an additional product (e.g. ProjectWise, OpenXxx) let us know about that too!
Sanyukta Joshi said:I am still trying to resolve this issue
Provide accurate information and sample data.
Sanyukta Joshi said:The text from autocad dgn file
I have Version 10.14.02.01.
