I have a lot of dgn files and don’t know which are V7 and which are V8. Is there a way to quickly and easily tell them apart? I would hate to have to go through and open them up individually.
This question was already answered, you need ISaDGN util then - RE: trying to load MicroStation 95 drawings (pre-V8)
I ran a script to pull the magic number of my DGNs and complied a list of valid ones. Thought it may help who ever comes across this.
Magic number: 4143313030390000 - R11/12 DWGMagic number: 4143313031340000 - R14 DWGMagic number: 4143313031350000 - R2000 DWGMagic number: 4143313031380000 - R2004 DWGMagic number: 4143313032340000 - R2010 DWGMagic number: 4143313032370000 - R2013 DWGMagic number: 4143313033320000 - R2018 DWGMagic number: 0809fe0200000000 - V7 DGNMagic number: 0809fe0200000108 - V7 DGNMagic number: 0809fe0200000188 - V7 DGNMagic number: 0809fe0200000881 - V7 DGNMagic number: 0809fe0200800108 - V7 DGNMagic number: 0809fe0201080000 - V7 DGNMagic number: 0809fe0201880080 - V7 DGNMagic number: 0809fe0208010000 - V7 DGNMagic number: 0809fe0263726f73 - V7 DGNMagic number: 0809fe0270656e75 - V7 DGNMagic number: 0809fe0274657374 - V7 DGNMagic number: 0809fe02776f726b - V7 DGNMagic number: c809fe0200000000 - V7 DGNMagic number: c809fe0200000188 - V7 DGNMagic number: c809fe0201080000 - V7 DGNMagic number: c809fe0201880080 - V7 DGNMagic number: c809fe0208010000 - V7 DGNMagic number: d0cf11e0a1b11ae1 - V8 DGN
Magic numbers aren't a fixed length, each application sets its own length, the magic number for a V7 file is c809fe02, the other numbers you're showing are part of the file data and can be ignored.
on DWG the first 4 bytes are always the ascii codes for AC10 (41433130) then the next 2 bytes are the version. Anything after the first 6 bytes is either padding or file data.
The v8 file format is special, it's actually a file format from Microsoft, not Bentley. It's called the Microsoft Compound File Binary File Format and may be used by more than MicroStation on your computer. So you may find a file with the same magic number but isn't actually a dgn file.
Also, I recently found this set of file formats at the US Library of Congress website. It's not comprehensive but has a lot of file formats. The ones I've check so far all have magic numbers
www.loc.gov/.../descriptions.shtml
John Doe said:I have a lot of dgn files and don’t know which are V7 and which are V8. Is there a way to quickly and easily tell them apart? I would hate to have to go through and open them up individually.
Why does it matter, if your microstation is configured properly it will convert v7 to v8 on the fly when they are opened, the only difference is the level names , pre v8 will not have level names just level number as the name... but if your going to isolate the v7 dgns in order to add level names from a library then I could understand.. but as almost nobody uses pre v8i it shouldn't present a problem.
I do like the powerscript magic number thing...
Lorys
