I have a lot of dgn files and don’t know which are V7 and which are V8. Is there a way to quickly and easily tell them apart? I would hate to have to go through and open them up individually.
John Doe said:I'll have to pursue other scripting means
it would be helpful if you published here what the alternative scripting was, I never heard of magic number in DOS and I'm not much use in powershell .. in your list of magic number outputs below
John Doe said:Magic number: 0809fe0200000000 - V7 DGNMagic number: 0809fe0200000108 - V7 DGN
the magic numbers vary between same format is this normal? Does your script add the type at the end, does it indicate the file names too like the poweshell script does
Lorys
can you explain this a bit better not good with poweshell
Kevin van Haaren said:Put that function in a file, then open PowerShell and do: . filename.ps1
. filename.ps1
I used a python script generated by chatgpt. It reads the first 8 bytes of all DGNs and outputs each unique "magic number" found among other things. I don't know if the variation is normal but that's what the script found.
Bentley's DGN iFilter is not compatible with pre-V8 DGNs, searching through over a million DGN files can be frustrating. This endeavor is to help alleviate this.
This is the answer!
MaryB
