Can someone guide me how can I get the TTF from the RSC file?
Please find the below MicroStation which details which I am using
Shabbeer
Shabbeer Shaik said: C:\Users\(username)\Documents\
Substitute your Windows username for (username). For example,
(username)
C:\Users\S.Shaik\Documents\
Hi, As MaryB said there is no direct way to generate the TTF from the RSC file In Microstaiton Connect Edition (Currently I am using Microstaiton Connect Edition update 16 and in Version 10.16.02.34). But in Microstaion V8i version we have the option to get the TTF fonts in temporary location with folder name GeneratedTTFonts. Could someone please confirm do we get TTF form RSC in Microstaiton Connect Edition (same as in Microstaion V8i version)?
Thank you MaryB
I believe the ISOCPEUR regular is equivalent to intl_iso ( well so an acader tells me) ... so I searched google and found site for FREE ttf fonts
https://www.dafontfree.net/isocpeur-regular/f130159.htm
now once you have it, how you add it so msnt can see it is another issue and so can all other users is another problem and if you have clients that want the actual cad files at project completion then that is a big problem for client to also have the external font added .. but I'm sure getting it for just in house is achievable..
Lorys
Lorys said:how you add it so msnt can see it is another issue and so can all other users is another problem
TrueType fonts should be installed to the C:\Windows\Fonts folder. The fonts become available to all apps and all users.
C:\Windows\Fonts
A TrueType font must be installed on each and every computer where it will be used. That's a Microsoft requirement, nothing to do with MicroStation.
Lorys said:If you have clients that want the actual CAD files at project completion then that is a big problem for client to also have the external font
The package delivered to the client should include the font and the client must install a TrueType font onto each of their Windows computers. Installing a font requires Windows admin rights. In contrast, a MicroStation RSC font is simply data that can be copied to a network location and shared like other MicroStation resources. You're right to raise this issue and perhaps Shabbeer Shaik might like to consider his reasons for requesting a TrueType font.
