When trying to Copy and Paste an AutoCAD Block version 13 (cell) from a DWG file using the commands CTRL+C and CTRL+V or Edit > Copy and Edit > Paste,
the Block will not paste into the DGN MicroStation V8i. With two sessions open;
In the DWG, the Block is selected, then copied (Edit > Copy) Moving the mouse into the DGN file, select Edit > Paste The Block can be seen on the end of the mouse cursor When clicking to accept the Paste command, the Block disappears and does not paste into the DGN
The message centers? are you talking about the key-in window? I see the part when I hit ctrl V but the second, I hit place with a left click of the mouse the part is gone. I do see below the key-in a message that said (Element selection> identify element to add to set)
Message Center generally docks here-
If it has something to tell you, you will see something there
Debra Turlich said:The message centers?
MicroStation Message Center: see this help topic.
Your screenshot shows that you are a ProjectWise client.
Debra Turlich said:Does that make a difference?
Probably not, but it always pays to describe your setup in full. Quite a few people on this Forum use ProjectWise, and will advise if they have met this problem.
yes does that make a difference?
