I want to change the case of dimension text to ALL CAPS. Right now I am going into each dimension text and then changing it to all caps as shown in image below. Is there a faster way of doing it?
Have you tried creating a selection set of all the elements then using this command - "changecase setaction uppercase"
I just tired it and it is not working as well.
Hi Harshi, in the Help documentation I search for "uppercase" and find
Change Text Case (bentley.com)
you find the Ribbon command there as well as a keyin that worked for me
Answer Verified By: Harshi Chauhan
Thanks Gerd, I used "Change case" icon but for some reason it was not allowing me to use fence. Anyways that icon saved me a lot of time. Thanks again.
Harshi Chauhan said: for some reason it was not allowing me to use fence
Hi Harshi,
The fence must be created first, before it can be used by another tool, such as change text case or change attributes.
Regards,Ron
