Problem with text and curved leaders. I have my proper settings for a curved text leader with a capsule text outline.
However, when I add the text, the leader becomes straight.
If I don't add text, and just make an line with arrow, the leader stays curved.
help please.
Back to the OP. I am not sure we have fully understood the workflow here. Can you provide some screenshots? You are editing your note? To become a multiline text? or just a single line.
CE
While CE is better, we actually need to know the exact version go to <File <Help <About
It's possible that the version you are using had an issue that was resolved in a newer version (if you are not using the latest version). Also, we need to know your work flow. Ex. What tool you are using, the tool settings, dimension style settings, etc.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
CONNECT EDITION UPDATE 17
VERSION 10.17.02.61.
UPON ADDING ANY TEXT WITHIN THE CAPSULRE, THE LEADER TURNS STRAIGHT AFTER I APPLY.
IF I APPLY A CAPSULE WITH NO TEXT, THEN THERE IS NO CAPSULE, AND NO TEXT, BUT THE LEADER APPEARS ALONE AND REMAINS CURVED..
