In V8i, when I would hover over a line for example, the line would turn pink, ready to be selected. Is this option available in Connect also, somewhere under preferences or somewhere? Thanks
Connect
Microstation Select S10 -vers 08.11.09.919
By default the Element Highlight Color can be set in Design File Settings below:File> Settings> File> Design File Settings> Color> Element Highlight Color
it can be also overridden if you tick on the Element Hilite options from the below Preferences setting:File> Settings> User> Preferences> View Options> Element Hilite
Part wiki reference:
Yes I am away of that setting. The problem is not the color, but the fact that the item does not hilite when I hover over it, like it did in v8i by default.
Microstation select series 10 ver 08.11.09.919
also have
CONNECT Ed Update 17
Version 10.17.02.61
Sorry for that. how about to -restoredefaults to reset the MicroStation to see if the highlight works again.
Besides element cannot be highlighted, does the Tool icon has the same issue either, the below wiki maybe worth to have a try. Thanks.Tool icon not highlighting
Hi Abel,
Try the following steps:
Here's a link to more Help documentation regarding AccuSnap Settings.
Regards,Ron
