Microstation connect edition error (0x64bf9c48)
Hi
i am facing with below error, what is the solution
Parents Reply
  • You didn't tell us if you are using PW or not.  this can have a huge impact on the reason why this is happening.
    As a repair option.......you can try and create a new DGN file (using the same seed file that the faulty file was created from) then reference in the faulty file.  within the reference dialog right click on the file and select merge into master.  this sometimes fixes these types of issues
    the new file will then become your active file....
    Ian
