Hi everyone,
Software Version: MicroStation Connect Edition Update 17 Version 10.17.02.61
I am trying to create a cell library with item types attached to each cell. The attachment of item types is via the model of a specific cell as I want to be able to edit the item properties when cells are placed into the model (See screenshot 1). I saved my cell library using DGN extension as I want also to use named presentation capability.
Screenshot 1
When I place one cell from that library into my test model, the explorer shows the quantity of items as 1, however when I generate predefined report the quantity is shown as 2 (Screenshot 2). When I add second cell into my model, then the explorer will show 2 items and the report will show 3 (Screenshot 3). Please note that the report shows the correct number of item types if these are attached directly into the elements within the test model (not from cell library).
Does anyone know what might be wrong and why item types are duplicated with the placement of first cell?
Screenshot 2
Screenshot 3
I have attached all test files.
Thanks in advance for your feedback.
.Test_Model.dgn
SYS_ItemTypes.dgnlib
MEP Cell Library.dgn
ItemTypesPickLists.xlsx
ItemTypesLookup.xlsx
Hi Jacek, I am able to reproduce this issue in MicroStation CE 17.2 with your files. Let me run tests on some other set of files and if reproducible, I will log a bug report for this.
Hi Karan,
Many thanks.
I found a little bit more about this duplicates. It seems like they are coming from Parametric Cell Definitions.
Thanks for reporting this issue Jacek. Bug #1181555 has been logged for this.
