Unable to get V8i task menuto load in MS Connect Edition update 16 (10.16.02.34)
Hi John,
Are you following the steps as mentioned in below wiki to enable V8i Task Theme:communities.bentley.com/.../enable-v8i-task-theme-in-microstation-connect-edition
You can also refer to below YouTube video:www.youtube.com/watch
Yes I did but still not getting the task menu to show up.
go to File>Settings>User
look down the list for "tasks - open the task navigation user interface" and select it
it should put you back in the file and open the task menu. If it still does not, go to the icon to the right of the workflows (upper left) and select the "dialog" option.
Timothy Hickman
Main: 877 627 3772|
