I've read this thread but doesn't answer my question:
DEFAULT LEVEL
I have a level called "Structure", which now I always hide, since have a new one called "New-Structure". The thing is, when I open Microstation double-clicking the dgn, the Structure level is marked as visible again and set as default in "Active level".
How can I override this thing and make Microstation preserve hidden levels as hidden when I close the app (after saving), and preserve also active level after reopening?
What version of MicroStation Are you running Please provide the 8 digit version number.
To Save the Current Settings to the Open DGN File do one of the following:
Key-in: FILEDESIGN
or
From the File tab, select Save Settings
Press <Ctrl+F>
Regards,Ron
Answer Verified By: quarich
MicroStation v10.16.1.319
Thanks, that did it.
