<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Inconsistent raster transparency when printing a sheet with copies of the same reference</title><link>https://communities.bentley.com/products/microstation/f/microstation-forum/244889/inconsistent-raster-transparency-when-printing-a-sheet-with-copies-of-the-same-reference</link><description>I&amp;#39;m printing a sheet that contains three references the same model rounding several bends. The referenced model has a background raster with transparency. On the sheet model, all three views indicate transparency; however when printing, only the lowest</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Inconsistent raster transparency when printing a sheet with copies of the same reference</title><link>https://communities.bentley.com/thread/783832?ContentTypeID=1</link><pubDate>Fri, 29 Sep 2023 01:27:17 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:ed4fee88-cf92-4455-abbd-4c4060f20ce9</guid><dc:creator>Lorys</dc:creator><description>&lt;p&gt;I used to create a holding xref file for the raster&amp;nbsp; attachent&amp;nbsp; and adjust the&amp;nbsp; brightness and contrast in the&amp;nbsp; raster ref manager&amp;nbsp; for the&amp;nbsp; holding&amp;nbsp; file, this will not change the actual raster only how it looks in the holding file , Then I attach this holding file as part of a nested ref and use&amp;nbsp; it as set only the order then&amp;nbsp; or&amp;nbsp; priorty to force it under all the&amp;nbsp; vector data.. this then can work for multiple sheets using the nested ref file&amp;nbsp; with the&amp;nbsp; holding&amp;nbsp; raster file set as below the vector .. makes for best consistent results over whole project and multiple&amp;nbsp; drafters use the same&amp;nbsp; xrefs for consistency and ease of use.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Inconsistent raster transparency when printing a sheet with copies of the same reference</title><link>https://communities.bentley.com/thread/783763?ContentTypeID=1</link><pubDate>Thu, 28 Sep 2023 12:26:56 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:277fb9c4-496d-4953-9cc6-efd88c17dca6</guid><dc:creator>Allan P.</dc:creator><description>&lt;p&gt;I will check that setting and let you know. I have been working with Steven&amp;#39;s suggestion of changing the brightness and contrast of the images in my reference which has accomplished more or less of my intent. &lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Inconsistent raster transparency when printing a sheet with copies of the same reference</title><link>https://communities.bentley.com/thread/783759?ContentTypeID=1</link><pubDate>Thu, 28 Sep 2023 11:42:43 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:6b74c44a-0bb2-4593-9914-3de0a1119955</guid><dc:creator>Mark Shamoun</dc:creator><description>&lt;p&gt;Hi Allan, i only have success when my rasters are in 2d models and my print driver configuration has &amp;quot;Enable Merging of Background Rasters&amp;quot; set. Could it be a priority issue?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Inconsistent raster transparency when printing a sheet with copies of the same reference</title><link>https://communities.bentley.com/thread/764393?ContentTypeID=1</link><pubDate>Fri, 05 May 2023 12:04:19 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:d7a96bcf-f40a-4edc-b9ed-99910f5fc332</guid><dc:creator>Steven Vander Giessen</dc:creator><description>&lt;p&gt;Are you controlling transparency solely through Reference Manager? If so, I have two other ideas for you that I use:&lt;/p&gt;
&lt;p&gt;- Control transparency via your pen table. There are dozens of ways to do this. Control the level that the rasters are on, or give all of the aerial references a logical name and control via that logical name, etc. The pen table may also be causing your problem so it&amp;#39;s worth investigating anyway.&lt;/p&gt;
&lt;p&gt;- I personally don&amp;#39;t use transparency on aerials. Instead I increase the brightness and decrease the contrast via the raster settings in the print dialog. Note that this does mean that you cannot have rasters anywhere else (logos, for example), but I prefer to vectorize that stuff anyway so the logos aren&amp;#39;t pixelated. Adjusting the brightness/contrast has the exact same effect as transparency, IMO, plus some other benefits like not highlighting small portions of rasters that might overlap a bit. +50 brightness and -30 contrast is a good start, but you can play around. I generally just adjust each in increments of 10. Don&amp;#39;t combine actual transparency with +brightness/-contrast because they will have an additive effect.&lt;/p&gt;
&lt;p&gt;Maybe not the total solution you were hoping for but just my thoughts.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
