Are there any restrictions on adding\modifying keyboard shortcuts in Microstation connect edition? I tried to follow the same steps for doing this in V8i version as well as the instructions about it for the Connect edition in the link below, but it does not seem to work.
Keyboard Shortcuts Dialog (bentley.com)
Kind regards,
Mamdouh
Mamdouh Mohamad said:what I am trying to do is to use the same shortcuts that I used to use in AutoCAD
Are you aware that MicroStation provides some AutoCAD key-ins?
yes Jon. The idea is that I am trying to use the exact same shortcuts that I was using, I am familiar with certain letters for commands that I have been using for years and just trying to figure out if it is possible to create my own punch of commands, sort to say. I am sure that this was påossible with the V8i version but just a bit disappointed that I can't probably do the same with the connect edition.
