Stretch with fence does not work in CONNECT as in v8i. In v8i most 3d solids I am able to use fence stretch. But in CONNECT I can’t stretch any 3d object, extruded or plain solid. I am not trying to stretch a shared cell either. I could not find a solution on bentleythanks
CONNECT Udate 17vers. 10.17.02.61Microstation v8i select sr 10version 08.11.09.919
I have the same problem. Missing this function. I use alot this tool.
