Stretch with fence does not work in CONNECT as in v8i. In v8i most 3d solids I am able to use fence stretch. But in CONNECT I can’t stretch any 3d object, extruded or plain solid. I am not trying to stretch a shared cell either. I could not find a solution on bentleythanks
CONNECT Udate 17vers. 10.17.02.61Microstation v8i select sr 10version 08.11.09.919
are you simply trying to make the extrusion longer ?
Timothy Hickman
Main: 877 627 3772|
yes longer or shorter pipe, something I use all the time.
Microstation select series 10 ver 08.11.09.919
also have
CONNECT Ed Update 17
Version 10.17.02.61
instead of the fence, try using the "modify solid" tool. Select the face and it will let you lengthen or shorten the pipe.
extrude in a different model seams to work fine by the looks of it, with stretch command. Unless I paste the extuded shape from the problem file, other wise it works fine. strange, at least I narrowed it down. thanks
another option would be to look at the properties of the solid, go to the extrude along path part and change the length.
