Stretch with fence does not work in CONNECT as in v8i. In v8i most 3d solids I am able to use fence stretch. But in CONNECT I can’t stretch any 3d object, extruded or plain solid. I am not trying to stretch a shared cell either. I could not find a solution on bentleythanks
CONNECT Udate 17vers. 10.17.02.61Microstation v8i select sr 10version 08.11.09.919
Glad you worked it out.
If I draw a circle and extrude along the line it works fine, but if I use the option circle profile and input a diameter, then it gives me a problem with stretching.
Microstation select series 10 ver 08.11.09.919
also have
CONNECT Ed Update 17
Version 10.17.02.61
Interesting, as a work around that work for now. did not know that before. thanks
I just tried that method myself Abel, and I can fence stretch the final extruded element.
inner and outer diameter are meant to create a pipe (walled cylinder) - why do you have the inner diameter set to zero ?
Timothy Hickman
Main: 877 627 3772|
