Stretch with fence does not work in CONNECT as in v8i. In v8i most 3d solids I am able to use fence stretch. But in CONNECT I can’t stretch any 3d object, extruded or plain solid. I am not trying to stretch a shared cell either. I could not find a solution on bentleythanks
CONNECT Udate 17vers. 10.17.02.61Microstation v8i select sr 10version 08.11.09.919
that is just a test sample. It does not seam to matter, even with a inner diameter I still get the same result.I am able to cut the pipe or cylinder, just not stretch.
Microstation select series 10 ver 08.11.09.919
also have
CONNECT Ed Update 17
Version 10.17.02.61
with a fence ? stretch not working - correct ? the methods I suggested work - correct ?
Timothy Hickman
Main: 877 627 3772|
The other option is to use the edit handles to stretch the solid.
Abel Vlad said:how do I attach a file?
Simply drag and drop in your post.
Best is it enable profile element using element properties tool and then adjust by it. Unfortunately the options are quite limited when need to edit solids without adding complexity of additional modifiers.
