Dumbest question yet!
Where do I find my User name, so I can log into the new Service Ticket whatever?
I've always logged into everything Bentley using an email address and password. This does not work with the new thing.
Hi Bob,
You will not use the "User name" field. Instead, you will need to log-in with your Bentley IMS log-in credentials (email & password).See the "Bentley Support Portal Quick Guide" contained in this link for the step-by-step process as well as more info on the new Bentley Support Portal.
-Jayson P.
When I try to log in with IMS, I get the message :
soooo...what does that mean, and who do I need to talk to?
MaryB
Hi MaryB,Thanks for the message.I will relay this info to our internal team in charge of the support migration.Will keep you posted on any resolution.Best,-Jayson P.
Yes, that works (Bentley IMS log-in). I was already logged in, so it went right to the page. My old, unresolved tickets are nowhere to be found! Perhaps that is why Bentley migrated to this new service?
I was able to get it, but same as Bob. None of my older unresolved tickets/cases are available.
Rod WingSenior Systems Analyst
