CIRCLE NOTE SCALES ON ITS OWN
I want to place a "circle note" (number with a circle frame around it) with no leader.  I don't have an issue creating the note but if I decide to edit the note to be a different number, the circle around the number increases in size automatically.  If I were to edit the note numerous times it would increase in size with each edit, making the circle way too large and the text remaining the same size.  Also, this issue is not present when the circle note has a leader, only when the circle note is by itself.  Seems like a bug but thought I would reach out if there is a setting I am missing.  see pic below for information when placing the note.  I don't understand what this means.  thanks.
  • the circle  note should scale  up and  down it was working in v8i as intended, but  I never liked  how you end  up with different size circles for different text lengths  like 1 letter or 2  letter  or even 3 letter  eg using it  for kerb set out ids  in order for me to have them all look the same  I had to look at the worst case before  placement  like if  only one  id had 3 characters like A99 so then all my ids had to be 3 characters   so I was forced  to call them A01 , A02 etc..... so all the circles  looked the same size and all the text looked the same size,  the only  other  option was to create  cell  with circle and text elements based on worst case to fit up to 3 characters  but not a note  circle, then when I copy paste , place or edit these the circle sizes never change.. it almost feels like its a backward st ep but the results  look better all the time..
    Lorys
    click link to PM me
