I have received some Autocad Civil 3D files, trying to open them within MicroStation only can be seen the frames and a text "AeccDbGraphCrossSection (AeccLand130)
There is an object enabler to see the civil 3d objects?
Hi Manuel,
What Object enabler did you install? Was Autodesk civil 3D 2023 Object Enabler.exe?
Be aware that up until recently, users could go to the Autodesk website and download object enablers as long as they had a valid login. Now it appears users have to have a subscription as the object enablers can no longer be found on the website and then downloaded.
Hola Maria, no he instalado ninguno, eso es lo que pregunto, si es que existe porque he leido que el Object enabler tiene que ser compatible con el real dwg, yo estoy trabajando con la última versión de connect edition y el RealDWG llega hasta la versión 2023, los que no tenemos un perfil en autodesk estamos fritos entonces? Que poco colabora autodesk en aras de la compatibilidad e interoperabilidad.
