<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Minimum line length definition</title><link>https://communities.bentley.com/products/microstation/f/microstation-forum/245445/minimum-line-length-definition</link><description>Hello,
 I&amp;#39;m trying to build a parametric section for a retaining wall.
 I have two parallel lines and I want to define a constraint between these lines so that line A will have a minimum length of line B.
 Currently I tried doing so by using the</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Minimum line length definition</title><link>https://communities.bentley.com/thread/768641?ContentTypeID=1</link><pubDate>Tue, 06 Jun 2023 11:43:43 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:c167ad6b-c86f-4b34-bcd0-6bafae94a531</guid><dc:creator>Carl Myhill</dc:creator><description>&lt;p&gt;Hello Alon&lt;/p&gt;
&lt;p&gt;Please confirm the version being used.&lt;/p&gt;
&lt;p&gt;Could it be that the wrong Variable is assigned to the element? It may be more helpful to supply a copy of the file in this instance for review.&lt;/p&gt;
&lt;p&gt;Using MicroStation CONNECT Edition Update 17.2, I placed 2 lines in a file and assigned Dimensional constraints &amp;#39;Bottom_stem_thickness&amp;#39; and &amp;#39;Top_stem_thickness&amp;#39; to each.&lt;/p&gt;
&lt;p&gt;I set the&amp;nbsp;&lt;span&gt;&amp;#39;Top_stem_thickness&amp;#39;&amp;nbsp;Variable to have an Active Value of 0.5&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;I set the&amp;nbsp;Bottom_stem_thickness&amp;#39; Min Variable Definition to&amp;nbsp;&amp;#39;Top_stem_thickness&amp;#39;&amp;nbsp;Active Value of 0.5&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;If I change the &amp;#39;Bottom_stem_thickness&amp;#39;&amp;nbsp;Active value to 0.2, there is no change as its below the value of&amp;nbsp;&amp;#39;Top_stem_thickness&amp;#39;&amp;nbsp;(0.5)&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;If I change the &amp;#39;Bottom_stem_thickness&amp;#39;&amp;nbsp;Active value to 0.8,&amp;nbsp;there is a change as its above the value of&amp;nbsp;&amp;#39;Top_stem_thickness&amp;#39;&amp;nbsp;(0.5)&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;So all appears to be OK.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;a href="https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/273/Min-Variable.mp4"&gt;communities.bentley.com/.../Min-Variable.mp4&lt;/a&gt;&lt;br /&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;If you want both lines to be the same in length, but also have a&amp;nbsp;Min length, one possibility may be to create another Variable lets call it &amp;#39;Min_Length&amp;#39; with a Active Value 0.5. Then assign &amp;#39;Min_Length&amp;#39; to both&amp;nbsp;&amp;#39;Top_stem_thickness&amp;#39;&amp;nbsp;&amp;amp; &amp;#39;Bottom_stem_thickness&amp;#39;&amp;nbsp;as the Min Variable Definition. Then set the Expression&amp;nbsp;&amp;#39;Bottom_stem_thickness&amp;#39; for the &amp;#39;Top_stem_thinkness&amp;#39; Variable&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;img style="max-height:240px;max-width:320px;" src="/resized-image/__size/640x480/__key/communityserver-discussions-components-files/273/pastedimage1686051794531v1.png" alt=" " /&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;a href="https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/273/Line-Length-with-Min.mp4"&gt;communities.bentley.com/.../Line-Length-with-Min.mp4&lt;/a&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
