Text searches using Microstation's explorer advance search does not work, how can I use search?
I have a cell that contains a text as part of the cell.  When I do a "Text" search (using Microstation's explorer advance search) for the string within the cell, it does not return a result.  I believe its because the text is treated as part of the cell and since it's searching for "Text" and not "Cells", it wont work.  When searching for "Cells" there is no text element I can select so this doesn't work either.  I want to be able to use search to find all instances of this cell, how can I get this to work?
